RE: New Exceed SP -03018
you sure you have the right ESC because the one I have has a reset button, it is set in there and is small but its there. plus mine went blippy too after a while but that's only from a dead battery. you should get a new battery and peak detecting charger too, I have 2 1500's that are faster than the battery mine came with(it won't help the weird thing it does when the battery dies but it will run better) also check the throttle trim
