RE: os .18
which one are you getting? the cvr or the tz? the cvr doesn't require a different header and is as close to a direct replacement that you will be able to find. you can use the same motor mounts but they will require some cutting to make them fit. I just did the CVR swap so if you need any more help if you go that route just let me know.
