RCU Forums - View Single Post - What did I do?! (Electronics / battery gurus, this is for you.)
Old 05-20-2008 | 04:57 PM
bruce88123
Default RE: What did I do?! (Electronics / battery gurus, this is for you.)
It's a 7 amp fuse. The LF on the side is the manufacturers ID-Little Fuse. The 7A is the fuse rating of 7 Amps. I've used a bunch of this type here at work.
http://www.littelfuse.com/data/en/Da...ts/251_253.pdf is a data sheet for this fuse or one VERY close to it.
