RE: What did I do?! (Electronics / battery gurus, this is for you.)
As to WHY it fried the RX? The fuse was protecting the circuit. Something (most likely the RX) was drawing too much power. By by-passing the fuse you removed the protection and allowed the bad RX to draw as much power as the battery could supply. That must have been over 7 amps or the fuse wouldn't have blown in the firt place. The RX had probably already failed. You finished it off and made any warranty worthless.[:@]
