RE: BME 115 - Reed travel / clearance
I would spend the $6 for the carb block mod and try that first. I do not think you will be happy with the sdc80.
After "stuffing" the reed block the burble should be gone unless you are to rich on the high needle. Most if not all of the burble is coming from the high needle, not the low as most would expect, but be careful when leaning the high and go very slowly.
