RCU Forums - View Single Post - replacement blades for e-flight blade cp
Old 05-20-2008 | 08:16 PM
rotarydoc
Default RE: replacement blades for e-flight blade cp
Hey Bob,
Thanks for the input...after reading your post, it got me wondering....I have a set of Eflite flat bottoms just sitting here, brand new. I slapped them on, just out of curiousity...I have been flying with symmetricals for quite some time now...and man, what a difference! It made the CP Pro much, much more stable, and as you said, exactly, it lifts off much sooner, and is flying around with much less head speed, which = better stability...
I got kinda carried away, and dinged them up a little, but they are fine with a little tape. I am definately going to get some of the HD1141's !! I really appreciate the tip...it really makes the CP Pro fun to fly again!
I have the Eflite G110 gyro on mine, and I have had good luck with it, the tail is pretty well locked, but it's not perfect all the time... but it sure is better than the stock gyro built into the 3 in 1, for sure! The biggest issue, of course is the tail motors...they don't last too long. I recently replaced mine, and the tail is behaving very, very well for a CP Pro! I still fly mine every day...and I love it. Sure, it's somewhat unstable, and has a mind of it's own sometimes, but that is good, it keeps me on my toes! I also have a couple of B400's, and practicing with the little CP Pro really helps me with the bigger birds; they seem so much more stable when I first fly the CPP, and then the B400... I have to honestly say that flying the CPP has helped my B400 flying!
Good luck with that gyro, should you end up getting it!
The Eflite gyro was a big improvement on my CPP...and the DX6i...those two things make it so much nicer to fly!
Thanks again, Glenn
