[quote]ORIGINAL: FastestJato
Yeah about the pen thing i already have that
The thing is that i take a normal computer paper cut it in inch by inche squres two of them then put the aginst the disk and the pads then screw the screws on till it touches the paper, Then my brakes dont work if i tighten a little too much it melts
I
P.S. off topic
out side temp is 65 F
Engine temp is 180 F
Sorry if I misread this, I'm pretty tired... Pads worn? Have something slimp on them? Look at the break mechanism. Figure out why they aren't "squeezing" enough. Maybe your servo is worn and can't generate the torque when they are properly adjusted. When you over adjust them they are dragging and all that fun friction stuff equals melt down. When in doubt dissassemble and reassemble. As for the temps they seem kind of low. Tune for performance not temp though. Altitude and all that good stuff plays a big role.
