RCU Forums - View Single Post - Best Basher?
Thread: Best Basher?
Old 05-20-2008 | 11:22 PM
Mspeed
Default RE: Best Basher?
The Jato has a spindle set up in the front so unless you have converted to the spindle set up on the pede you will not be able to swap the fronts out. On the backs, since you have gone wide pede, I take it you changed to the offset rims that the jato uses stock. Even if you dont use the offset rims in the back on the pede, the hexes are the same so yes the jato rims will work. The spindle set up is actually stronger and has a bit lower rotating mass (more performance) than the pede set up in stock form. The jato is like a safisticated rustler, you get more adjustments for racing, 2 speed, and much better shocks. Everything is enginneer to keep the center of gravity as low as you possibly can, even the motor has a option to lower it flat against the chassis.
