RCU Forums - View Single Post - Plane Specifications
Old 05-21-2008 | 11:28 AM
Osirisf16's Avatar
Osirisf16
Default Plane Specifications
hey guys, i just want to know what each one of a plane's specs is.
Here are the Great Planes "U Can Do 3D" plane specs:
SPECS: Wingspan: 56.75" (1441mm)
Wing Area: 904 sq in (58.3 sq dm)
Weight: 5 - 5lbs 10oz (2268-2551g)
Wing Loading: 12.7-14.3 oz/sq ft (39-44 g/dm2)
Incidence:
Wing: 0°
Stab: 0°
Engine: 1.5° down, 2° right
Length: 58.5" (1486mm)
Airfoil: Fully-symmetrical mid-wing
Center of Gravity: 4¾" (120mm) Back from the wing's leading edge
Control Throws-
Elevator: High Rate(3D) Up & Down 2¼" (57mm) Low Rate 1" (25.4mm)
Rudder: High Rate(3D) Right & Left 3½" (89mm) Low Rate 1½" (38mm)
Ailerons: High Rate(3D) Up & Down 2½" (63.5mm) Low Rate 1¼" (32mm)
The U-Can-Do 3D is covered with the following MonoKote colors:
Please, share with me a little knowledge of what each thing is, shall you?
