RCU Forums - View Single Post - Glow Igniter issue, I think.
Old 05-21-2008 | 12:41 PM
opjose's Avatar
opjose
Default RE: Glow Igniter issue, I think.
Re: Battery
The HotShot 2 has a small grub screw that permits you to open the "CAN".
I believe you can change the battery, but I have never done so.
I do have the (GP?) anodized ignitor with indicator in the scew off cap from Tower too.
On this one I took a 2200mAh battery from a new RX pack I had, which had a bad cell, and cut off the tabs, then stuffed it into the ignitor.
It lasts quite a bit longer now.
TH sells loose battery cells to make your own packs.
These make excellent replacements for the cell in your ignitor.
In your shoes I'd just buy a second ignitor and carry two.
Use one primarily, and next year or so, look at changing out the battery.
Why waste what you already have?
