RE: inverted engines
They only burn out if the the engine is run too lean.
There's a few guys here running with 10 year old glow plugs!
What can happen instead is that the coil will get coated with debris. This is usually the reason to change out the glow plug.
If the last two loops of your plug ( closest to the end ) do not light up then it may be time to replace it.
