Lesson Learned Cap BP
Had a mishap with my Cap BP where the Motor Mount came off, totally my fault I accidentally glued the mount on and never put the screw back in well the ca gave and the motor mount motor came off the plane. actually flew better without motor which tells me i need more weight in the tail lol. well anyway I shrunk wrapped the connectors to the speed controller and motor but cut a sliver so it would make it easy to remove the motor and speed controller from each other. so this is the second lesson i learned make sure your connectors are moderately loose from the speed controller because I still had power for servos to safely glide to the ground. still had a plane but couldnt find the motor it was in tall grass and only found part of the motor.
