RCU Forums - View Single Post - Starting engine..
Old 05-21-2008 | 06:38 PM
ehroof
Default RE: Starting engine..
if you remove the air filter, there is an opening there, when you apply the throttle, there is an opening that shows up, there should be a 1mm opening when at idle, if not, you need to turn the idle screw until there is a 1mm opening.
