RCU Forums - View Single Post - Lightest weight conversion engine?
Old 05-21-2008 | 10:54 PM
buck1856's Avatar
buck1856
My Feedback: (49)
Default RE: Lightest weight conversion engine?
Any of the weedies can be made light by a lot of cutting,ect.The only problem is that the pull starter and clutch are the heavier parts that youll need plus youll need the housing all in tack to hold the generator head.You wont gain anything at all.Just go to honda and buy the little camping one they sell.Its like 750 watts or somthing.Check out the internet for used from auctions and clearance houses.Make an L shaped frame from wood and 2 dufffle bag straps and your done.[I would preferably just use a gas weedie instead of using an electric one with a generator attached to my back.
