RCU Forums - View Single Post - My First Crawler
Old 05-22-2008 | 03:28 AM
cflight
Default RE: My First Crawler
May I suggest checking allelectronis for gear head/ geared motors?
They have all sorts of gearhead motors , stock changing regularly. If you run a gearhead to a transfer case, say some 1/4" flat stock aluminum, housing four bearings, two shafts and drilled out pinions, ... you got a transfer case needing some drive cups or drive shafts.
I've found brazing tubing is the easiest chassis if you have a torch, chopping aluminum stocks fun if you have a cut wheel....?
