RE: New mcd cy motor tuning trouble(gas tank)!
i was thinking of an air leak too. what i would do would be as 'da mad" said, set it back to the stock settings and check for air leaks.. make sure you clean the plug up and check it to see if its running lean.. also check the exhoust. it can run lean if its got an air leak at the manifold..
