RE: TELEBEE/ZOOM HH GYRO ISSUE
Sounds like you have the gyro in the correct orientation. You need to do the set up as per finles bobs video on the helifreak site. Go to helifreak and create a login and search for zoom gyro setup and watch the video. You need to set it up in rate mode to hold the tail and then you need to adjust for servo creep in HH mode with the sub trim. Once you do that then you need to set the gain by the end point adjustments in the radio on both ends to stop the wag. Watch the video and will help you to understand.
