Saito
You won't need to remove the cam to pull the crank out. The gear teeth on the crank are just straight spur cut teeth and the crank will just slide right out. Not so on a YS, OS, nor some of the lesser engines. An Enya crank can be pulled right off the front leaving the cams still timed.
