RCU Forums - View Single Post - Prop slipping on spinner?
Old 05-22-2008 | 08:27 PM
bigedmustafa's Avatar
bigedmustafa
Default RE: Prop slipping on spinner?
I had similar trouble on a Thunder Tiger F-91s 4-stroke when I tried using the plastic spinner that came with the ARF. I removed it and bolted the prop directly to the thrust washer while using a safety spinner nut on top of the double lock nuts at the end of the crank shaft.
Plastic backed spinners and 4-strokes just don't mix.
