RCU Forums - View Single Post - Hovering a PBF
Thread: Hovering a PBF
Old 05-07-2003 | 05:51 PM
Hacker
Default Hovering a PBF
aerobat66,
it is a common problem...i had to name mine
GEO EXPLORER i dorked it so many times from that attitude. you do have to catch it right now with the elevator to prevent it.you just sort of get use to it after a while and make the correction with out thinking about it. also where is your cg?should be at about 5 3/4 " back from le or even 6".
if your falling over on its back and your more than one or two mistakes high you should be able to fly out inverted with full power.
