RCU Forums - View Single Post - Wren Idle Problem (Again)
Old 05-23-2008 | 09:09 AM
Gaspar's Avatar
Gaspar
Default RE: Wren Idle Problem (Again)
That's not correct.
The ecu calibrate the idle power every and each time that the engine arrive to idle during startup phase. Just in the moment of that the rotor RPM arrive to idle the ecu store the current pump power as "idle setting" for this particular run.
Gaspar
