RCU Forums - View Single Post - KMP Beechcraft Bonanza's!
Old 05-23-2008 | 12:10 PM
  #43
SLONLOW
My Feedback: (26)
Default RE: KMP Beechcraft Bonanza's!
Building UPDATE:..Wings, Have been joined. They set in perfectly with each other. Checked for incidence and washout. Perfect!! Ailerons and Flaps have been installed previously, retracts, lines and servos have been installed as well. Control horns have not been installed as of yet. FUSE: Nose retract has been installed, retract/valve servo and air valve and air tank have been installed. After running the lines, I found out that I was short about a Foot of Air line. No matter, used some spare clear line I had. I strengthend the servo tray by installing 1/4 by 1/8 hardwood under the servo mounting holes. Installed both elevator servos as well as steering servo and steering cable. NICE !! I pulled the original elevator control rod guides out. These came out with no problem. I installed a pair of Semi-Flex carbon rods for the elevators. Much sturdier. Elevators will be installed tomorrow as well as cowl trial fit with ASP 1.60 twin. Building is slow I know, too much work and getting ready for wedding...my own.hehe..
