RE: Zenoah G38 and G62 same problem
Make sure the flywheel, containing the magnet, hasn't moved. A friend of mine had a 38 that would only pop.
When we investigated further we found that the Woodruff key on the crankshaft had sheared. This allowed the flywheel to move slightly on the crankshaft and hence put the timing of the spark out slightly.
Hope this helps
Colin
