RCU Forums - View Single Post - thrust test prop selection
Old 05-23-2008 | 07:18 PM
octanehuffer's Avatar
octanehuffer
Default RE: thrust test prop selection
I may be wrong here but I thougt that a DA 150 will give about 90 lbs thrust. The 40% planes usually have at least 2:1 thrust to weight ratio. Someone should enter those props and rpm's into Pe Rievers thrust calculator to see if they correspond.
