RCU Forums - View Single Post - No foam inserts?
Old 05-23-2008 | 09:49 PM
ravenlunatic
Default RE: No foam inserts?
thanks for the responses guys...i've actualy been runing this set up for a for a few runs and it seems realy grippy for me. i feared the dreaded deflating issue and so far i have not experienced any, it seems the rings hold tight enough to where no air will escape. as for the bounce factor, i don't think the scopion wieghs enough to flatten out the tires, i've jumped it many times and noticed that the truck was bouncing alot more with the foams (it was the real reason i took them out). i'll be runing this set up untill i run into issues, if i do, i'll be sure to let you guys know.
