RE: What the heck is going on with my Tsunami?
I have the red cat brushless system. Using nimh battery
With a venom 3600 battery, 10 minutes then after it starts to chug when the battery is low.
Venom 5000, around 20 minute use then it weirds out.
With the stock REDCAT 1800mah battery about 4-5 minutes use then it dies.
What kind of charger do you have? Maybe the cells are damaged in your battery. How many amps do you charge your battery with? Is you battery old?
