RCU Forums - View Single Post - OS 4 strokes
Thread: OS 4 strokes
Old 05-24-2008 | 12:05 PM
Campgems
Default RE: OS 4 strokes
ORIGINAL: gaRCfield
What about the ratings for size - the Pulse 40 is suggested to run with a .40-.46 2 stroke, or .56-.82 4 stroke. Does this mean that one will get similar performance from a .46 2 stroke and a .82 4 stroke? What would compare to a .55 2 stroke? How do they come up with these size ranges?
I fly both O.S and Magnum four strokes. The 52 four stroke is equivlant in overall power to a 40 size two stroke. THe four stroke can swing a bigger prop and has better throttle response. Two things that are a pluss for a plane like the Pluse. You are not going to fly it at full throttle for more than a couple seconds at a time. What you want is quick and reilable throttle response throughtout the range and lost of low end thrust. I'm just getting my feet wet in a Phenoex Fun Star. I've got a O.S 52 in it cranking a 13x4 apc. I am flying at 1/3 throttle. In fact the meager instructions warn you not to fly at full throttle for any length as the control surfaces will start to flutter. I can't imagine a 70 on this plane, although the extra weight would be good. I had to add 6 oz of weight to the firewall and a 70 weighs just about 60z more than the 52.
I have a Magnum 70 in a Ruperts Dad, a build from plans plane that callls for a 52 four stroke. That one also needed weight up front so that is one reason I used the 70. The wingspan on it is about 8" longer thant the fun Star and the plane weights about a pound more. The seventy is a good choice for it. I crank a 14x4w APC withi it. Compairing the Fun Star to the Ruperts, the Fun Star seems to have a ton more power.
I also fly a Magnum 91 in a 4*60. Again all the power you could ask for. All three planes are not speedy, so the four strokes are great fits for them.
Don
