RE: Idle problems
Low speed too lean adn idle screw open too far. Could also be a little lean on the high speed but a real sign of lean low speed is teh high idle off wide open throttle. Reset your needles back to factory. Then make very small adjustments on the high speed needle then tune the low speed and idle. Do a pinch test for idle. It should die within 3-5 seconds once line is pinched.
