RCU Forums - View Single Post - charging maxamps 6000 with hyperion 610i
Old 05-24-2008 | 04:12 PM
trexquest
Default charging maxamps 6000 with hyperion 610i
I'm trying to charge a max amp 6000 with a hyperion eos610i with included balancer. I' m using a river gate 15amp ps. The charger I have set for lipo 7.4 2s, 1c 6ooo mah, 6 amp.Set charge to 100% safety timer 180 min. With the ps and charger hooked up I plug in the bal in the 2s slot, then I plug in the main battery plug. When I press enter for 2 seconds it shows solo mode ok, then press enter again says checking battery then it comes back and says battery not detected. Tryed many times same thing, used four different lipos same problem. The bal mode reads voltage both cells but when to start bal mode reads battery not detected. I used the charger to charge nimi charged fine, can you help.thank you
