RE: KMP Beechcraft Bonanza's!
OK sorry here we go. Here You can also see the airlines I had to use because I did not have enough of the original ones that came with it. I made some very small holes in the wings to pull them thru along with the servo leads. This must be done before joining the wing halves together. You can also see the tubes used to hold the Elevator stabs onto the fuse. Very rigid. Very nice. Make sure you run some 60 grit sand paper over them before glueing in so that they dont come off.
