EF Extra 260 480 trim question
I've flown my E Flite Extra 260 480 a couple times now and it flies great, however I have to add several clicks of L aileron to trim properly. When I put everything together, I used a square to make certain the horizontal and vertical stabs were at 90* angles-or so I thought.
After the second flight, I re-measured everything and noticed the vertical stab has a slight "lean" to the left. It's apparently too late to do anything now as it's CA'd in place. Could/would the vert stab leaning left a degree or two cause the plane to bank right slightly?
