RCU Forums - View Single Post - Reading piston tops.
Old 05-24-2008 | 09:08 PM
Tired Old Man
Default RE: Reading piston tops.
Rich,
You're still much too early o be obtaining any useful info from the engine. The only thing I can see right now is that you're using a lot of oil in the fuel, the mixture is on the rich side, and like Pe noted, it's a mineral oil. The bottom of the pistons will look ash grey or white if you've been running them too lean, too hard, or too hot.
Hughes500E:
