RCU Forums - View Single Post - .30 size Waco
Thread: .30 size Waco
Old 03-16-2002 | 02:10 PM
Ron C
My Feedback: (35)
Default waco 30
I have one also , and as Flyindoc stated ,the landing gear area is weak, might want to peel the covering back and glass this area before you install the gear,, also i used a OS 26 surpass, a good engine ,but this plane needs more power, Go with a good 25 2 stroke. Mount the engine as far forward as possible,. I had to use a heavy hub to get mine to balance properly. Take offs are a bit tricky, try to fly on a calm day, mine didnt like the wind at all. Easy to land, very good roll rate, fair to not so good , on all other aerobatics
--, this plane requires 5 MICRO servos , be prepared to spend over a 100 bucks, if you dont already have some
