RE: Homelite 25cc engine tune
If it has the ZAMA carb, you can reduce the idle speed by plugging the holes on the carb butterfly. However, you will find the standard carb will lean out at high RPM. I modified my ZAMA endlessly until I simply replaced it with a Walbro WA-167. Tunability, power, and peak RPM increased enormously.
