I use the BruLine fine air filter on my engines because I figure the couple of dollars for the filter is cheaper than a piston/liner set
. It also stops fuel spitting back out the carb so the outside stays cleaner too. Some engines can leak fuel quite badly from the front bearing but this tends to get spread all over the model, not just behind the carb.
