RE: Filter on glow?
And no two engines are alike, you may have a little slop in the crankcase and it is letting pressure back through and out the carb. The crankshaft is actally a valve, it rotates to open and close so the fit between it and the case is important. You may want to disassemble and inspect it to be sure it didn't swallow some rocks and ruin the seal.
