RE: Eldorada top plate
That micro temp works good if you program it right. some people read it at the same rate as a gun and if its set up right it gives you max tenps when your running. you can pull over and your temps will drop 20 or 30 degrees [&o] so you guys with a gun are not as close as you think [&:]
