RCU Forums - View Single Post - Problem with going full throttle
Old 05-26-2008 | 09:31 AM
da Rock
Default RE: Problem with going full throttle
There is a thread in this forum that is about your problem.
Our engines need the needle valve set in order to run wide open without sagging, and to give full power. The new ones sometimes need the low-speed or idle needle set in order to go cleanly throttle up from idle to wide open.
This thread covers that:
http://www.rcuniverse.com/forum/m_7536819/tm.htm
