RCU Forums - View Single Post - Prop / Battery selection
Old 05-26-2008 | 09:38 AM
ozrcboy's Avatar
ozrcboy
Default RE: Prop / Battery selection
ORIGINAL: Pitts-SPS
This gived me around 6 minutes of flight time.
I was flying yesterday and I was advised by fellow modellers that the prop was too small for that size motor.
If I increase the prop, won't I get less flight time?
What about if I go to a 4 cell pack?
It depends - a larger prop will draw more current at wide open position, but a larger prop also tends to be more effeicient, so provided you show some restraint you may get more thrust for your watts with a larger prop.
If you go to a 4 cell pack the motor will spin faster, drawing more amps. You will be able to go faster but you may need a smaller prop to stop the motor getting overloaded.
Thing to do is to get yourself a wattsup or other power meter and actually measure your current flow with different props - that way you can pick the right prop that doesn't overload the battery/ESC/motor etc.
Cheers,
Oz.
