RE: Is your Voltwatch 2 doing this??
How are you charging the packs?
If you have a charger that can do it, you could charge and discharge the packs and see what capacity they are rating at.
If not, you could charge them and then test them in a plane on the ground and see how long they last. If the voltwatch is connected you can see how fast they drain down.
