RE: Lightest weight conversion engine?
Your probably better off using magneto ignition instead of electronic. Considering the runtime per battery charge, you will have to find some way to charge the ignition battery. That means that your backpack will also include a battery charger of some sort. Using the generator as a starter does away with the main advantage of the electronic ignition ie. easy starting.
