Fuel dot setup
Im in the process of building a H9 P-47 thunderbolt 60 with a saito FA100 in it. The engine mounts slightly inverted. About 7 o'clock to 8 o'clock to be exact. My question is this. By puting a fuel dot in it due to the cowl, would a "T" work or would it be advised to pick up a tank with 3 lines. I have seen people use the T's before, but not inverted. I wonder if it would be prone to flooding by using a T rather than a 3 line tank. I dont want to have to remove the cowl to get to the glow plug to pull it if it floods. I plan on using a remote glow system to avoid cutting up the cowl.
Any input would be appreciated.
