RCU Forums - View Single Post - JBA .75 LEAN problem
Old 05-26-2008 | 04:03 PM
waterloged's Avatar
waterloged
Default RE: JBA .75 LEAN problem
If the engine is that tight it is probably working very hard and no amount of adjusting on the needle will help, you might check the bearings and find out what is making the engins so stiff. You might need a new set of bearings or the crank might be gummed or seized up. Just tear it down and find the stiff[&o] parts then it will run fine if its not destroyed (hope)
