RE: Final control suface adjustment?
I do not have that particular plane and if it happens that you could not find the right info, I would suggest you to go 1/2" right and left on rudder and as per the cg try to locate it close to the main spar of the wing (Thickest part of the ribs), and you should be safe there. Try some test flights and then rearrange the control surfaces and CG until you feel it comfortable.
