RCU Forums - View Single Post - Initial Engine Run Questions
Old 05-26-2008 | 07:55 PM
DMcQuinn
My Feedback: (13)
Default RE: Initial Engine Run Questions
Make sure the needle valve is 2.5 turns open. CLose it gently until it stops. Then open it (CCW) 2.5 turns. As a diagnostic, you can put some fuel tubing on the carburetor nipple and blow air from your mouth. This will help you confirm that the fuel passage is open through the needle valve.
