RCU Forums - View Single Post - Fuel dot setup
Old 05-26-2008 | 08:20 PM
da Rock
Default RE: Fuel dot setup
ORIGINAL: f_shawn68
darock, what issues is it you have had with fuel dots? Is the vibration on the light fiberglass cowl too much for them? I will be mounting my saito in the recommended location with the muffler coming out the bottom on center. I see what you are saying and a hemostat and T on the pressure line just might be the route I go. ?
I've only tried a fuel dot once. It wound up sticking on fueling and losing pressure in flight, all in the same weekend. And while trying to fix it discovered that a couple of my flying buddies didn't use them anymore. They'd had the same problems.
The hemostat actually isn't needed in every case. Depends on what line you're placing the T in. And how you fuel. My hand pumps put out pretty strong pressure and have no problem delivering full flow into the tank at the same time it merrily pumps about as much fuel down the other line off the T. I've got one plane with the T in the carb line. Even with my pumps pressure, fueling using that line doesn't flood the engine. Most needle valves restrict flow lots more than an empty tank resists filling (which isn't much).
