RCU Forums - View Single Post - Help with throttle servo setup
Old 05-27-2008 | 12:17 AM
KidVermin
Default RE: Help with throttle servo setup
Cub,
All you can do is have a very small gap showing on the throttle barrel opening till you start it up and get the low end idle screw and main jet set. Then you can adjust the throttle trim on the Tx
Oops, forgot to mention you need to have a little servo closing movement left when the barrel is near closed. Using the outer most hole on the longest factory servo arm, you'll be able to have full open and close.
