My guess would be tail heavy. I'd check the CG before you messed with the wing. If the CG is right then I would try adding some down thrust on the engine by adding a couple of washers behind the engine mount. After that mess with the wing...
pimmnz and dignlivn are right throttle controls altitude...try it DaveyWA I guarantee your landings will improve.
