ORIGINAL: islandturbos
ORIGINAL: firstrc
I have the red cat brushless system. Using nimh battery
With a venom 3600 battery, 10 minutes then after it starts to chug when the battery is low.
Venom 5000, around 20 minute use then it weirds out.
With the stock REDCAT 1800mah battery about 4-5 minutes use then it dies.
What kind of charger do you have? Maybe the cells are damaged in your battery. How many amps do you charge your battery with? Is you battery old?
If the 3000 mah battery is a redcat battery it will not work no matter what the answers are to those questions... It is a known problem (known at redcat) that the redcat 3000mah's do not work with the redcat brushless.
The only redcat battery i have is the stock 1800mah battery and it works with my brushless for a few mins
Yeah the 1800's will work but only for a few minutes as you said. The problem is known so far only with the 3000's
