RE: Convert GMS 120 glow to Gas
A ring is pinned so that the end gap is ALWAYS on a solid part of the cylinder wall. If you installed the piston turned 180 degrees when you reinstalled it, then maybe the end of the ring was passing a port opening and finally caught.
